2pot
Véhicule : Impreza
Re: [CHASSIS] Choix de suspensions .
Messagepar 2pot » lun. oct. 09, 2017 18:31
Revo a écrit :
2pot a écrit :Le ressort avant STI pink (nouveau) le plus court, sur un AGX est comprimé de 17mm sur l'assemblage (à l'aide d'un nouvel isolateur en caoutchouc).
Any opinion on that combo? Do you think it will work well on the long term? I'm also concerned by the height ratio, with the front diving like this I'm afraid this accentuates understeer.
Some like stiff springs and small bars, others like softer springs and bigger bars.
If you think the WR15's are too stiff, on your particular roads, don't get coilovers :2)
The P11L have the same front spring rate as the lowered pinks, but the P11L are 15mm higher at the front.
My concern with the lowered sti pinks is the low ride height combined with the low spring rate - do you use Whiteline KCA313 or SuperPro trc0002? If not, get a kit.
Hopefully, you are using the soft front bump stops with the pinks? To maximise the very limited compression travel.
But, your front tyres might touch the wheel arches on rough roads or during hard cornering. Big bars might reduce the roll enough to stop the tyre to arch contact. You should be OK at the rear, due to the WR15 rear bump stops. If you get front tyre contact, use the clip-on spacers.
The first line of defence is normally the bump stop. But, in your case, you have to use a soft stop, with the pinks, because you have little or no compression travel. The final defence is the top spring perch hitting the strut body - this stops the strut bottoming out.
The lowered sti pinks were designed to use the very hard 60mm bump stops in the inverted struts - the lowered pinks ride on those bump stops all the time, which increases the spring rate. But, this gives a poor ride quality and more understeer.
Messagepar JFO » lun. oct. 09, 2017 18:39
"2pot", écrit et comprend le Français, alors que nous....(pour la plupart) :sweat: ;-)
Revo
Véhicule : Sub GT 99
Messagepar Revo » lun. oct. 09, 2017 20:47
2pot a écrit :Some like stiff springs and small bars, others like softer springs and bigger bars.
I don't know, maybe it's just the fact that AGX are not good enough to react at low speed impacts. I know you said they were successfully bench tested together though. I still have to step in a Subaru that is equiped with B16 coilovers, to make my opinion about them on the street!
2pot a écrit :The P11L have the same front spring rate as the lowered pinks, but the P11L are 15mm higher at the front.
Yes, I do have this kit installed. (and I wish I chose the P11L in the first place! But I'm really enjoying all these experiments now, no regrets).
2pot a écrit :Hopefully, you are using the soft front bump stops with the pinks? To maximise the very limited compression travel.
Yes, I am using the softer front bump stops, but I believe I did feel them getting hit indeed, when I did a longer test drive today. No tyre to arch contact issues yet, with stock wheels.
Overall it feels a bit too "blury" in my taste at faster pace, but the comfort is really good on the street (for a sports car). I don't feel like the bigger bars are helping them either, it's like it's locking the whole front end, I don't know how to explain that... I might be experiencing what you call roll-rock. I have to admit I keep better memories of the Pro Kit with the same bars for mixed road usage. I was just believing the Pink would perform better on the track, but I might be wrong.
Actually I'm already thinking of selling them to a friend who drives an STI v5 and is about to install stock inverted struts, that would work better for him.
I have the opportunity to test stock STI v6 springs on the AGX. Is this worth a try in your opinion? I have very few information on these springs (rates and expected height). I'm getting used to mount/unmount my suspensions now anyway :lol:
Thanks for the instructive replies as always.
JFO a écrit :"2pot", écrit et comprend le Français, alors que nous....(pour la plupart) :sweat: ;-)
On écrit un anglais assez clean, donc google translate devrait te donner de bons résultats !
Messagepar JFO » lun. oct. 09, 2017 20:55
mieux que "Reverso" !!!? :mrgreen: :mrgreen:
Messagepar JFO » lun. oct. 09, 2017 21:47
Revo a écrit :On écrit un anglais assez clean, donc google translate devrait te donner de bons résultats !
JFO a écrit :mieux que "Reverso" !!!? :mrgreen: :mrgreen:
tu as raison ; c'est nettement mieux compréhensible avec G.translate !! ;-)
2pot
Véhicule : Impreza
Messagepar 2pot » lun. oct. 09, 2017 21:48
Ressorts v6sti sont 41.5N/mm avant et 34N/mm arrière.
Revo
Messagepar Revo » lun. oct. 09, 2017 21:54
2pot a écrit :Ressorts v6sti sont 41.5N/mm avant et 34N/mm arrière.
That's much higher than I expected, rate wise similar to the WR15R/T's then, probably not height wise. Given they are OEM springs, I assume they are linear too. I will give them a shot out of curiosity!
Messagepar JFO » lun. oct. 09, 2017 22:21
C'est beaucoup plus élevé que prévu, taux similaire aux WR15R / T alors, probablement pas la bonne hauteur. Étant donné qu'ils sont avec des ressorts OEM, je suppose qu'ils sont aussi linéaires. Je vais les essayer par curiosité !
that's right !?
Messagepar THE SHADOW » mar. oct. 10, 2017 01:48
Sur la Mazda
:unsure: ????
Messagepar THE SHADOW » mar. oct. 10, 2017 01:57
that's right !?
Oui, essayer ce set up, est une bonne idée .
Revo
Messagepar Revo » mar. oct. 10, 2017 09:51
THE SHADOW a écrit :
Sur la Mazda
:unsure: ????
Je confirmais que sur ma Mazda MX6, ce sont, comme sur la Subaru GT de freestyler, des inserts Koni non inversés montés dans des jambes de force d'origine ;-)
Messagepar JFO » mar. oct. 10, 2017 11:42
Revo a écrit :Je confirmais que sur ma Mazda MX6, ce sont, comme sur la Subaru GT de freestyler, des inserts Koni non inversés montés dans des jambes de force d'origine ;-)
comme ce que j'ai.....toujours pas monté sur la mienne, par contre pour les ressorts, qui sont avec..!!? je mettrai des photos
Revo
Messagepar Revo » ven. oct. 13, 2017 22:32
Cette semaine j'ai donc récupéré des suspensions (incomplètes - juste amortisseurs, ressorts, et coupelles supérieures) de STI 6 d'origine, pour un ami.
En attendant de les lui remettre, il m'a autorisé à faire des tests.
J'ai monté les Pink sur les amortisseurs de STI 6.
Image Image
Je trouve que ça se comporte mieux que sur les AGX.
J'ai pris une photo ce soir :
Prochain test : les ressorts de STI 6 sur les AGX. Je m'attends à être déçu au niveau confort, et à repasser sur les Pro Kit.
Messagepar JFO » mar. oct. 17, 2017 13:58
si quelqu'un pouvait me dire, la marque des ressorts !? ( je ne pense pas que ce soit des des Eibach !?)
le gars qui me les a vendus, n'a pas roulé avec ; ils étaient sur la GT qu'il venait d'acheter pour la monter en Gr.FN !!
Revo
Messagepar Revo » mar. oct. 17, 2017 14:14
Difficile à dire s'ils sont repeints sans marquages visibles.
Je trouve les spires des ressorts avant nombreuses par rapport à ce qu'on a l'habitude de voir (en général une de moins).
Faudrait prendre une photo de dessus, mais tes coupelles inférieures semblent mal orientées.
Revo
Messagepar Revo » sam. oct. 21, 2017 18:57
Montage des ressorts STI 6 avorté, ça s'annonçait aussi court que les Pink à l'avant.
De retour en Eibach Pro Kit sur les AGX à mi-dureté, et barres anti-roulis harmonisées en Cusco 22mm avant et arrière.
Prochaine étape rencontrer quelqu'un qui a des B16 pour voir ce que ça donne, et qui sait, peut-être en acheter.
Messagepar JFO » sam. oct. 21, 2017 20:12
Revo a écrit :Faudrait prendre une photo de dessus, mais tes coupelles inférieures semblent mal orientées.
qu'est-ce que tu appelles coupelles inférieures , l'arrêt du ressort sur la jambe de force, en position symétrique pour les arrières sur la photo !?
Revo
Messagepar Revo » sam. oct. 21, 2017 20:31
Les coupelles qui sont en dessous des coupelles supérieures
Gabi
Véhicule : Impreza GT99
Messagepar Gabi » mar. nov. 28, 2017 10:50
Pour information j'ai monté sur ma Subaru GT des Eibach P11L à la place des ressorts de STi6.
En effet ils étaient un peu trop durs pour les routes de campagne cassantes sur lesquelles je roule.
Et vu que je ne fais pas circuit, ils ne correspondaient pas à mon utilisation.
Voilà une photo des ressorts montés sur mes amortisseurs Ohlins :
Un grand merci à Mark (2pot) pour avoir répondu à toutes mes questions, son sérieux, et de me les avoir envoyé aussi rapidement ! B)
Je vends d'ailleurs les ressorts de STi 6 si ça intéresse quelqu'un.
2pot
Véhicule : Impreza
Messagepar 2pot » mar. nov. 28, 2017 16:17
^ ^_^
P11L + KYB Excel-G
Revenir vers « Chassis »
