[WRX/STI]Codes d'erreur (CE)
XNWRX
Messagepar XNWRX » dim. juin 12, 2005 22:07
by Crichon :
P0031 Front oxygen (A/F) sensor heater circuit low input
P0032 Front oxygen (A/F) sensor heater circult high input
P0037 Rear oxygen sensor heater circuit malfunction
P0038 Rear oxygen sensor heater circuit high input
P0065 Air assist injector solenoid valve malfunction
P0066 Air assist injector solenoid valve circuit low input
P0067 Air assist injector solenoid valve circuit high input
P0101 Mass air flow sensor circuit range/performance problem (high input)
P0102 Mass air flow sensor circuit low input
P0103 Mass air flow sensor circuit high input
P0106 Pressure sensor circuit range/performance problem (low input)
P0107 Pressure sensor circuit low input
P0108 Pressure sensor circuit high input
P0111 Intake air temperature sensor circuit range/performance problem
P0112 Intake air temperature sensor circuit low input
P0113 Intake air temperature sensor circuit high input
P0117 Engine coolant temperature sensor circuit low input
P0118 Engine coolant temperature sensor circuit high input
P0121 Throttle position sensor circuit range/performance problem (high input)
P0122 Throttle position sensor circuit low input
P0123 Throttle position sensor circuit high input
P0125 Insufficient coolant temperature for closed loop fuel control
P0128 Thermostat malfunction
P0130 Front oxygen (A/F) sensor circuit range/performance problem (lean)
P0131 Front oxygen (A/F) sensor circuit range/performance problem (low input)
P0132 Front oxygen (A/F) sensor circuit range/performance problem (high input)
P0133 Front oxygen (A/F) sensor circuit slow response
P0136 Rear oxygen sensor circuit malfunction
P0139 Rear oxygen sensor circuit slow response
P0171 Fuel trim malfunction (A/F too lean)
P0172 Fuel trim malfunction (A/F too rich)
P0181 Fuel temperature sensor A circuit range/performance problem
P0182 Fuel temperature sensor A circuit low input
P0183 Fuel temperature sensor A circuit high input
P0244 Wastegate control solenoid valve malfunction (high input)
P0245 Wastegate control solenoid valve circuit low input
P0246 Wastegate control solenoid valve circuit high input
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
P0327 Knock sensor circuit low input
P0328 Knock sensor circuit high input
P0335 Crankshaft position sensor circuit malfunction
P0336 Crankshaft position sensor circuit range/performance problem
P0340 Camshaft position sensor circuit malfunction
P0341 Camshaft position sensor circuit range/performance problem
P0420 Catalyst system efficiency below threshold
P0442 Evaporative emission control system malfunction
P0444 Evaporative emission control system purge control valve circuit low input
P0445 Evaporative emission control system purge control valve circuit high input
P0447 Evaporative emission control system vent control low input
P0448 Evaporative emission control system vent control high input
P0451 Evaporative emission control system pressure sensor range/performance problem
P0452 Evaporative emission control system pressure sensor low input
P0453 Evaporative emission control system pressure sensor high input
P0456 Evaporative emission control system malfunction
P0457 Evaporative emission control system leak detected (fuel filler cap loose/off)
P0461 Fuel level sensor circuit range/performance problem
P0462 Fuel level sensor circuit low input
P0463 Fuel level sensor circuit high input
P0464 Fuel level sensor intermittent input
P0480 Cooling fan relay 1 circuit low input
P0483 Cooling fan function problem
P0500 Vehicle speed sensor malfunction
P0506 Idle control system RPM lower than expected
P0507 Idle control system RPM higher than expected
P0508 Idle control system circuit low input
P0509 Idle control system circuit high input
P0512 Starter switch circuit high input
P0545 Exhaust gas temperature sensor circuit low input
P0546 Exhaust gas temperature sensor circult high input
P0604 Internal control module memory check sum error
P0703 Brake switch input malfunction
P0705 Transmission range sensor circuit malfunction
P0710 Transmission fluid temperature sensor circuit malfunction
P0715 Torque converter turbine speed sensor circuit malfunction
P0720 Output speed sensor (vehicle speed sensor 2) circuit malfunction
P0725 Engine speed input circuit malfunction
P0731 Gear 1 incorrect ratio
P0732 Gear 2 incorrect ratio
P0733 Gear 3 incorrect ratio
P0734 Gear 4 incorrect ratio
P0741 Torque converter clutch system malfunction
P0743 Torque converter clutch system (Lock-up duty solenoid) electrical
P0748 Pressure control solenoid (Line pressure duty solenoid) electrical
P0753 Shift solenoid A (Shift solenoid 1) electrical
P0758 Shift solenoid B (Shift solenoid 2) electrical
P0778 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunction
P0785 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunction
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (opencircuit)
P1095 Tumble generator valve circuit #1 (overcurrent)
P1096 Tumble generator valve circuit #2 (opencircuit)
P1097 Tumble generator valve circuit #2 (overcurrent)
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit perfomance/range problem
P1141 Mass air flow sensor circuit range/perfomance problem (low input)
P1142 Throttle position sensor circuit range/performance problem (low input)
P1146 Pressure sensor circuit range/performance problem (high input)
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1400 Fuel tank pressure control solenoid valve circuit low input
P1420 Fuel tank pressure control solenoid valve circuit high input
P1443 Evaporative emission control system vent control function problem
P1480 Cooling fan relay 1 circuit high input
P1507 Idle control system malfunction (fail-safe)
P1510 Idle air control solenoid valve signal 1 circuit low input
P1511 Idle air control solenoid valve signal 1 circuit high input
P1512 Idle air control solenoid valve signal 2 circuit low input
P1513 Idle air control solenoid valve signal 2 circuit high input
P1514 Idle air control solenoid valve signal 3 circuit low input
P1515 Idle air control solenoid valve signal 3 circuit high input
P1516 Idle air control solenoid valve signal 4 circuit low input
P1517 Idle air control solenoid valve signal 4 circuit high input
P1518 Starter switch circuit low input
P1540 Vehicle speed sensor malfunction 2
P1544 High exhaust temperature detected
P1560 Back-up voltage circuit malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle position sensor circuit malfunction for automatic transmission
P1701 Cruise control set signal circuit malfunction for automatic transmission
P1703 Low clutch timing control solenoid valve circuit malfunction
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
Alex37
Messagepar Alex37 » ven. mai 19, 2006 10:13
à toutes fin utiles un site qui donne les resolutions des CE (pour RS2.5 mais bcp de choses idem aux euro)
http://glasairproject.com/library.html
Messagepar OLM77 » mer. avr. 25, 2007 18:22
http://www.jade-obd2.com/index.html?lan ... ubaru.html
Code Description
P1086 Entrée de circuit de sonde de position de la valve #2 (main gauche) de générateur de dégringolade basse
P1087 Entrée élevée de circuit de sonde de position de la valve #2 (main gauche) de générateur de dégringolade
P1088 Entrée de circuit de sonde de position de la valve #1 (Rhésus) de générateur de dégringolade basse
P1089 Entrée élevée de circuit de sonde de position de la valve #1 (Rhésus) de générateur de dégringolade
P1090 Défaut de fonctionnement de la valve #1 (Rhésus) de générateur de dégringolade (ouverts coincés)
P1091 Défaut de fonctionnement de la valve #1 (Rhésus) de générateur de dégringolade (coincé étroitement)
P1092 Défaut de fonctionnement de la valve #2 (main gauche) de générateur de dégringolade (ouverts coincés)
P1093 Défaut de fonctionnement de la valve #2 (main gauche) de générateur de dégringolade (coincé étroitement)
P1094 Circuit #1 (circuit ouvert) de valve de générateur de dégringolade
P1095 Circuit #1 (courant de valve de générateur de dégringolade d'excédent)
P1096 Circuit #2 (circuit ouvert) de valve de générateur de dégringolade
P1097 Circuit #2 (courant de valve de générateur de dégringolade d'excédent)
P1100 Défaut de fonctionnement de circuit de commutateur de démarreur
P1101 Entrée élevée de circuit de commutateur de position neutre (A/T)
P1101 Défaut de fonctionnement de circuit de commutateur de position
neutre (M/T)
P1102 Défaut de fonctionnement de circuit de valve de solénoïde de sources de pression
P1103 Sources de pression commutant le circuit de valve de solénoïde
P1104 Défaut de fonctionnement de circuit de signal de commande de couple de moteur
P1106 Défaut de fonctionnement de circuit du signal de commande de couple de moteur 2
P1110 Entrée de sonde de pression atmosphérique basse
P1111 Entrée élevée de sonde de pression atmosphérique
P1112 Gamme de sonde de pression atmosphérique/problème d'exécution
P1115 Entrée élevée de circuit de signal de coupe de commande de couple de moteur
P1116 Entrée de circuit de signal de coupe de commande de couple de moteur basse
P1120 Entrée élevée de commutateur de démarreur
P1121 Entrée élevée de circuit de commutateur de position neutre [véhicules de la TA]
P1121 Entrée de circuit de commutateur de position neutre basse [aux véhicules]
P1122 Entrée élevée de circuit de soupape à trois voies de sources de pression
P1124 Entrée élevée de circuit de signal de CTCs
P1130 Défaut de fonctionnement avant de circuit de sonde de l'oxygène (circuit ouvert)
P1131 Défaut de fonctionnement avant de circuit de sonde de l'oxygène (court-circuit)
P1134 Problème avant de micro-ordinateur de sonde de l'oxygène (A/F)
P1137 Gamme de circuit de sonde de l'oxygène (A/F)/problème d'exécution avant
P1139 Exécution de circuit de réchauffeur de la sonde #1 de l'oxygène (A/F)/problème avant de gamme
P1141 Entrée élevée d'air de circulation de circuit de masse de sonde
P1142 Basse entrée d'air de circulation de circuit de masse de sonde
P1143 Entrée de circuit de sonde de pression basse
P1144 Entrée élevée de circuit de sonde de pression
P1146 Gamme de circuit de sonde de pression/problème d'exécution (entrée élevée)
P1150 Entrée élevée de l'oxygène de sonde de circuit avant de réchauffeur
P1151 Entrée élevée de l'oxygène de sonde de circuit arrière de réchauffeur
P1230 Défaut de fonctionnement d'unité de commande de pompe d'essence
P1244 Défaut de fonctionnement de valve de solénoïde de commande de Wastegate (basse entrée)
P1245 Défaut de fonctionnement de valve de solénoïde de commande de Wastegate (fiable)
P1301 Le feu dû à la température d'échappement accrue
P1312 Défaut de fonctionnement de sonde de température d'échappement
P1325 Entrée de circuit de sonde de coups basse
P1400 Entrée de solénoïde de commande de pression de réservoir de carburant basse
P1420 Entrée élevée de solénoïde de commande de pression de réservoir de carburant
P1421 Entrée élevée de circuit de recirculation de gaz d'échappement
P1422 Entrée élevée de circuit de soupape de commande de purge
d'EVAP
P1423 Entrée élevée de commande de passage d'EVAP
P1440 Entrée de système de commande de pression de réservoir de carburant basse
P1441 Entrée élevée de système de commande de pression de réservoir de carburant
P1442 Chaîne de circuit de sonde de niveau de carburant/perforation
P1443 Problème d'opération de service de passage de système de commande d'EVAP
P1480 Le ventilateur transmettent par relais 1 entrée élevée de circuit
P1500 Défaut de fonctionnement de circuit du relais 1 de ventilateur de radiateur
P1501 Défaut de fonctionnement à vide de système de commande (de sécurité)
P1502 Problème de fonction de ventilateur de radiateur
P1507 Défaut de fonctionnement à vide de système de commande (de sécurité)
P1510 Basse entrée d'air de commande de solénoïde de circuit à vide du signal 1
P1511 Entrée élevée d'air de commande de solénoïde de circuit à vide du signal 1
P1512 Basse entrée d'air de commande de solénoïde de circuit à vide du signal 2
P1513 Entrée élevée d'air de commande de solénoïde de circuit à vide du signal 2
P1514 Basse entrée d'air de commande de solénoïde de circuit à vide du signal 3
P1515 Entrée élevée d'air de commande de solénoïde de circuit à vide du signal 3
P1516 Basse entrée d'air de commande de solénoïde de circuit à vide du signal 4
P1517 Entrée élevée d'air de commande de solénoïde de circuit à vide du signal 4
P1518 Entrée de circuit de commutateur de démarreur basse
P1520 Entrée élevée de circuit du relais 1 de ventilateur de radiateur
P1540 Défaut de fonctionnement 2 de sonde de vitesse de véhicule
P1544 La température d'échappement élevée a détecté
P1560 Défaut de fonctionnement de secours de circuit de tension
P1590 Entrée élevée de circuit de commutateur de position neutre
P1591 Entrée de circuit de commutateur de position neutre basse
P1592 Circuit de commutateur de position neutre (modèle de la TA)
P1594 Défaut de fonctionnement de circuit de signal d'entrée de diagnostic de transmission automatique
P1595 Entrée de circuit de signal d'entrée de diagnostic de transmission automatique basse
P1596 Entrée élevée de circuit de signal d'entrée de diagnostic de transmission automatique
P1698 Entrée de circuit de signal de coupe de commande de couple de moteur basse
P1699 Entrée élevée de circuit de signal de coupe de commande de couple de moteur
P1700 Défaut de fonctionnement de circuit de sonde de position de commande de puissance (A/T)
P1701 Défaut de fonctionnement réglé de circuit de signal de commande de croisière (A/T)
P1702 Circuit automatique de signal d'entrée de diagnostic de transport
P1703 Bas défaut de fonctionnement de circuit de valve de solénoïde de commande de synchronisation d'embrayage
P1704 2-4 défaut de fonctionnement de circuit de valve de solénoïde de synchronisation de frein
P1705 2-4 circuit de valve de solénoïde de pression de frein (solénoïde D)
P1711 Défaut de fonctionnement de circuit du signal de commande de couple de moteur 1
P1712 Défaut de fonctionnement de circuit du signal de commande de couple de moteur 2
P1722 Entrée élevée automatique de signal d'entrée de diagnostic de transport
P1742 Défaut de fonctionnement automatique de signal d'entrée de diagnostic de transport
^_^
cemoititi
Messagepar cemoititi » lun. mai 14, 2007 15:25
Je veux juste y mettre ma dose à moi aussi vu qu'il en manque pas mal plus haut :P
si y'en a qui ne sont pas d'accord avec les infos cidessous, merci de le faire savoir ;-)
Source: http://www.scoobypedia.co.uk/index.php/Knowledge/OBDIITroubleCodeDefinitions
OBDII Code OBDII Trouble Code Description
P0011 A Camshaft Position System Performance (Bank 1)
P0021 A Camshaft Position System Performance (Bank 2)
P0026 OSV Solenoid Valve L Malfunction
P0028 OSV Solenoid Valve L Malfunction
P0030 O2 Sensor Heater Circuit Range/Performance Bank 1 Sensor 1
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0043 HO2S Heater Control Circuit Low Bank 1 Sensor 3
P0044 H02S Heater Control Circuit High Bank 1 Sensor 3
P0050 O2 Sensor Heater Circuit Range/Performance Bank 2 Sensor 1
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0057 HO2S Heater Control Circuit Low Bank 2 Sensor 2
P0058 HO2S Heater Control Circuit High Bank 2 Sensor 2
P0063 HO2S Heater Control Circuit Low Bank 2 Sensor 3
P0064 HO2S Heater Control Circuit High Bank 2 Sensor 3
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 Manifold Pressure Sensor Range/Performance
P0076 OSV Solenoid Valve L Circuit Malfunction Low
P0077 OSV Solenoid Valve L Circuit Malfunction High
P0082 OSV Solenoid Valve L Circuit Malfunction Low
P0083 OSV Solenoid Valve L Circuit Malfunction High
P0101 Mass or Volume Air Flow Circuit Range Performance
P0106 Manifold Pressure Sensor Circuit Range/Performance Problem (Low)
P0107 Manifold Pressure Sensor Circuit Malfunction (Low Input)
P0108 Manifold Pressure Sensor Circuit Malfunction (High Input)
P0111 Intake Air Temperature Sensor Range/Performance Problem
P0112 Intake Air Temperature Sensor Circuit Malfunction (Low Input)
P0113 Intake Air Temperature Sensor Circuit Malfunction (High Input)
P0128 Coolant Thermostat
P0129 Atmospheric Pressure Sensor Range/Performance
P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
P0130 O2 Sensor Circuit (Lean) (Bank 1 Sensor 2)
P0130 O2 Sensor Circuit Bank 1 Sensor 1
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit Open Bank 1 Sensor 1
P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Bank 1 Sensor 3
P0143 O2 Sensor Circuit Low Voltage Bank 1 Sensor 3
P0144 O2 Sensor Circuit High Voltage Bank 1 Sensor 3
P0145 O2 Sensor Circuit Slow Response Bank 1 Sensor 3
P0150 O2 Sensor Circuit Bank 2 Sensor 1
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit Open Bank 2 Sensor 1
P0156 O2 Sensor Circuit Bank 2 Sensor 2
P0157 O2 Sensor Circuit Low Voltage Bank 2 Sensor 2
P0158 O2 Sensor Circuit High Voltage Bank 2 Sensor 2
P0159 O2 Sensor Circuit Slow Response Bank 2 Sensor 2
P0162 O2 Sensor Circuit Bank 2 Sensor 3
P0165 O2 Sensor Circuit Slow Response Bank 2 Sensor 3
P0170 Fuel Trim (Bank 1)
P0171 System Too Lean (Bank 1) - usually caused by a leak in the intake system somewhere between the Mass Air Flow sensor and the cylinder intake valves. Look for a vacuum hose that’s become disconnected or a crack in one of the tubes connected to the turbocharger
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0181 Fuel Temperature Sensor A Performance Problem
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0196 Oil Temperature Sensor Circuit Range/Performance Problem
P0197 Oil Temperature Sensor Circuit Malfunction Low
P0198 Oil Temperature Sensor Circuit Malfunction High
P0222 Throttle Position Sensor B Low Input
P0223 Throttle Position Sensor B High Input
P0230 Fuel Pump Controller
P0244 Turbocharger Wastegate Solenoid A Range/Performance (High Input)
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0261 Fuel Injector Circuit Low - #1
P0264 Fuel Injector Circuit Low - #2
P0267 Fuel Injector Circuit Low - #3
P0270 Fuel Injector Circuit Low - #4
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0325 Knock Sensor 1 Circuit Malfunction
P0327 Knock Sensor 1 Circuit Malfunction (Low Input)
P0328 Knock Sensor 1 Circuit Malfunction (High Input)
P0330 Knock Sensor 2 Circuit Malfunction
P0332 Knock Sensor 2 Circuit Malfunction (Low Input)
P0333 Knock Sensor 2 Circuit Malfunction (High Input)
P0345 Camshaft Position Sensor A Circuit Bank 2
P0350 Ignition coil primary/secondary circuit
P0365 Camshaft Position Sensor B Circuit (Bank 1)
P0390 Camshaft Position Sensor B Circuit (Bank 2)
P0400 EGR System
P0420 Catalyst System Efficiency Below Threshold
P0442 EVAP Control System Leak Detected (Small Leak)
P0444 Canister Purge Control Solenoid Valve Circuit Low
P0445 Canister Purge Control Solenoid Valve Circuit High
P0447 EVAP Control System Vent Control Circuit Open
P0448 EVAP Control System Vent Control Circuit Short
P0451 Fuel Tank Pressure Sensor Performance Problem
P0452 Fuel Tank Pressure Sensor Circuit Low Input
P0453 Fuel Tank Pressure Sensor Circuit High Input
P0456 EVAP Control System Leak Detected (Very Small Leak)
P0457 EVAP Control System Leak Detected (Fuel Cap Loose/Off)
P0458 Canister Purge Control Solenoid Valve Circuit Low
P0459 Canister Purge Control Solenoid Valve Circuit High
P0480 Cooling Fan Relay 1 Circuit Low
P0483 Cooling Fan Rationality Check Malfunction
P0501 Vehicle Speed Sensor Malfunction at Low Speed
P0502 Vehicle Speed Sensor Low Speed
P0503 Vehicle Speed Sensor High Speed
P0506 Idle Control System RPM Lower than Expected
P0507 Idle Control System RPM Higher than Expected
P0508 Idle Control System Circuit Low
P0509 Idle Control System Circuit High
P0513 Incorrect Immobilizer Key
P0519 Idle Control System Malfunction (Fail-Safe)
P0545 Exhaust Gas Temperature Sensor Circuit Malfunction (Low Input)
P0546 Exhaust Gas Temperature Sensor Circuit Malfunction (High Input)
P0558 Alternator Circuit Low
P0559 Alternator Circuit High
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control Set Signal
P0579 Cruise Control Switch Circuit Range Performance Problem High Input
P0600 Improper CAN Communication
P0601 Internal control module memory check sum error
P0604 Internal control module random access memory error
P0605 Internal Control Module Read Only Memory Error
P0607 Throttle Control System Circuit Range/Performance
P0638 Throttle Control Circuit Range/Performance Problem
P0641 Throttle Position Sensor A Power Supply Circuit
P0661 Intake Manifold Tuning Valve Circuit Low
P0662 Intake Manifold Tuning Valve Circuit High
P0691 Cooling Fan Relay 1 Circuit Low
P0692 Cooling Fan Relay 1 Circuit High
P0700 Request AT MIL On
P0703 Brake Switch Circuit Malfunction for AT
P0703 Brake Switch Circuit Range Performance Problem High Input
P0705 AT Range Switch Circuit Malfunction
P0710 ATF Temp. Sensor Circuit Malfunction
P0712 ATF Temp Sensor Circuit Low
P0713 ATF Temp Sensor Circuit High
P0715 Torque Converter Turbine Speed Signal Circuit Malfunction
P0716 Torque Converter Turbine Speed Signal Circuit Malfunction
P0719 Brake Switch Circuit Low
P0720 AT Vehicle Speed Sensor Circuit High
P0720 AT Vehicle Speed Sensor Circuit Malfunction
P0722 AT Vehicle Speed Sensor Circuit Low
P0724 Brake Switch Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Malfunction
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0741 Torque Converter Clutch Circuit Malfunction
P0743 Torque Converter Clutch Circuit Electrical (Duty Sol. B)
P0748 Pressure Control Solenoid Electrical (Duty Sol. A)
P0751 Shift Solenoid A Malfunction
P0753 Shift Solenoid A Electrical
P0756 Shift Solenoid B Malfunction
P0758 Shift Solenoid B Electrical
P0761 Shift Solenoid C Malfunction
P0763 Shift Solenoid C Electrical
P0766 Shift Solenoid D Malfunction
P0768 Shift Solenoid D Electrical
P0771 AT Low Clutch Timing Solenoid Valve Circuit Malfunction
P0771 Shift Solenoid E Malfunction
P0773 Shift Solenoid E Electrical
P0778 AT 2–4 Brake Pressure Solenoid Valve Circuit Malfunction
P0785 AT 2–4 Brake Timing Solenoid Valve Circuit Malfunction
P0801 Reverse Inhibit Control Circuit
P0817 PN Signal Output Circuit
P0851 Neutral Switch Input Circuit Low
P0852 Neutral Switch Input Circuit High
P0864 TCM Communication Circuit Range/Performance
P0865 TCM Communication Circuit Low
P0866 TCM Communication Circuit High
P0880 PIVGN Power Supply Circuit
P0882 PIVGN Power Supply Low
P0883 PIVGN Power Supply High
P0955 Backup Lamp Relay Output Open
P0957 Backup Lamp Relay Output Low
P0958 Backup Lamp Relay Output High
P1026 VVL Systems 1 Performance
P1028 VVL Systems 2 Performance
P1086 Tumble Generated Valve Position Sensor 2 Circuit Low
P1087 Tumble Generated Valve Position Sensor 2 Circuit High
P1088 Tumble Generated Valve Position Sensor 1 Circuit Low
P1089 Tumble Generated Valve Position Sensor 1 Circuit High
P1090 Tumble Generated Valve System 1 (Valve Open)
P1091 Tumble Generated Valve System 1 (Valve Close)
P1092 Tumble Generated Valve System 2 (Valve Open)
P1093 Tumble Generated Valve System 2 (Valve Close)
P1094 Tumble Generated Valve Signal 1 Circuit Malfunction (Open)
P1094 Tumble Generated Valve Signal 2 Circuit Malfunction (Open)
P1095 Tumble Generated Valve Signal 1 Circuit Malfunction (Short)
P1097 Tumble Generated Valve Signal 2 Circuit Malfunction (Short)
P1102 Pressure Sources Switching Sol. Valve Circuit Low
P1110 Atmospheric Pressure Sensor Circuit Malfunction (Low Input)
P1111 Atmospheric Pressure Sensor Circuit Malfunction (High Input)
P1112 Atmospheric Pressure Sensor Circuit Range/Performance
P1122 Pressure Sources Switching Sol. Valve Circuit High
P1130 O2 Sensor Circuit (Open) (Bank 1 Sensor 1)
P1131 O2 Sensor Circuit (Short) (Bank 1 Sensor 1)
P1134 A/F Sensor Micro-Computer Problem
P1135 O2 Sensor Circuit (Open) (Bank 2 Sensor 1)
P1136 O2 Sensor Circuit (Short) (Bank 2 Sensor 1)
P1137 O2 Sensor Circuit (Lambda=1) (Bank 1 Sensor 1)
P1137 O2 Sensor Circuit (Mid) (Bank 1 Sensor 1)
P1139 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1)
P1140 O2 Sensor Heater Circuit Range/Performance (Bank 2 Sensor 1)
P1143 Pressure sensor circuit range/performance (low)
P1144 Pressure sensor circuit range/performance (high)
P1146 Manifold Pressure Sensor Circuit Range/Performance Problem
P1152 O2 Sensor Circuit Range/Performance (Low) Bank 1 Sensor 1
P1153 O2 Sensor Circuit Range/Performance (High) Bank 1 Sensor 1
P1154 O2 Sensor Circuit Range/Performance (Low) Bank 2 Sensor 1
P1155 O2 Sensor Circuit Range/Performance (High) Bank 2 Sensor 1
P1160 Return Spring Failure
P1199 Differential Pressure Sensor
P1230 Fuel Pump Controller
P1235 Intake Control Valve Solenoid Circuit Low
P1236 Intake Control Valve Solenoid Circuit High
P1237 Exhaust Control Valve Solenoid Circuit Low (Positive Pressure)
P1238 Exhaust Control Valve Solenoid Circuit High (Positive Pressure)
P1239 Exhaust Control Valve Solenoid Circuit Low (Negative Pressure)
P1240 Exhaust Control Valve Solenoid Circuit High (Negative Pressure)
P1241 2 Stage Twin Turbo System (Single)
P1242 2 Stage Twin Turbo System (Twin)
P1244 Turbocharger Wastegate Solenoid A Range/Performance (Low Input)
P1245 Turbocharger Wastegate Solenoid A Range/Performance (fail-safe)
P1247 Relief Valve Control Solenoid 1 Circuit Low
P1248 Relief Valve Control Solenoid 1 Circuit High
P1249 Relief Valve Control Solenoid 2 Circuit Low
P1250 Relief Valve Control Solenoid 2 Circuit High
P1282 PCV System Circuit (Open)
P1301 Misfire Detected (High Temperature Exhaust Gas)
P1306 OCV Solenoid Valve Signal 1 Circuit Malfunction (Open)
P1307 OCV Solenoid Valve Signal 1 Circuit Malfunction (Short)
P1308 OCV Solenoid Valve Signal 2 Circuit Malfunction (Open)
P1309 OCV Solenoid Valve Signal 2 Circuit Malfunction (Short)
P1312 Exhaust Gas Temperature Sensor Malfunction
P1313 Misfire Detected Signal Circuit High Input
P1314 Misfire Detected Signal Circuit Low Input
P1400 Fuel Tank Pressure Control Solenoid Valve Circuit Low
P1420 Fuel Tank Pressure Control Solenoid Valve Circuit High
P1442 Fuel level sensor performance problem (travel distance)
P1443 Vent Control Solenoid Valve Function Problem
P1446 Fuel Tank Sensor Control Valve Circuit Low
P1447 Fuel Tank Sensor Control Valve Circuit High
P1448 Fuel Tank Sensor Control Valve Range/Performance
P1475 Exhaust bypass valve solenoid Malfunction Low
P1476 Exhaust bypass valve solenoid Malfunction High
P1477 Exhaust bypass valve function
P1480 Cooling Fan Relay 1 Circuit High
P1491 Positive Crankcase Ventilation (Blow-by) Function Problem
P1492 EGR Solenoid Valve Signal #1 Circuit Malfunction (Low Input)
P1493 EGR Solenoid Valve Signal #1 Circuit Malfunction (High Input)
P1494 EGR Solenoid Valve Signal #2 Circuit Malfunction (Low Input)
P1495 EGR Solenoid Valve Signal #2 Circuit Malfunction (High Input)
P1496 EGR Solenoid Valve Signal #3 Circuit Malfunction (Low Input)
P1496 EGR Solenoid Valve Signal #4 Circuit Malfunction (Low Input)
P1497 EGR Solenoid Valve Signal #3 Circuit Malfunction (High Input)
P1497 EGR Solenoid Valve Signal #4 Circuit Malfunction (High Input)
P1507 Idle Control System Malfunction (Fail-safe)
P1510 ISC Solenoid Valve Signal #1 Circuit Malfunction (Low Input)
P1511 ISC Solenoid Valve Signal #1 Circuit Malfunction (High Input)
P1512 ISC Solenoid Valve Signal #2 Circuit Malfunction (Low Input)
P1513 ISC Solenoid Valve Signal #2 Circuit Malfunction (High Input)
P1514 ISC Solenoid Valve Signal #3 Circuit Malfunction (Low Input)
P1515 ISC Solenoid Valve Signal #3 Circuit Malfunction (High Input)
P1516 ISC Solenoid Valve Signal #4 Circuit Malfunction (Low Input)
P1517 ISC Solenoid Valve Signal #4 Circuit Malfunction (High Input)
P1521 Brake Switch Circuit Range Performance Problem High Input
P1544 Exhaust Gas Temperature Too High
P1547 Exhaust Gas Temperature Sensor Malfunction
P1559 Air Intake System
P1560 Back-up Voltage Circuit Malfunction
P1570 Antenna
P1571 Reference Code Incompatibility
P1572 IMM Circuit Failure (Except Antenna Circuit)
P1573 Communication Error (Time Over)
P1574 Key Communication Failure
P1576 EGI Control Module EEPROM
P1577 IMM Control Module EEPROM
P1590 Neutral Position Switch Circuit High Input for AT
P1591 Neutral Position Switch Circuit Low Input for AT
P1592 Neutral Position Switch Circuit Malfunction for MT
P1593 TCM Communication Circuit Malfunction
P1594 AT Diagnosis Input Signal Circuit Malfunction
P1595 AT Diagnosis Input Signal Circuit Low Input
P1596 AT Diagnosis Input Signal Circuit High Input
P1597 TCS Signal Circuit Low Input
P1598 TCS Signal Circuit High Input
P1600 Improper CAN Communication
P1601 Tranmission Ctrl Unit Comms Malfunction
P1698 Engine Torque Control Cut Signal Circuit Malfunction (Low Input)
P1699 Engine Torque Control Cut Signal Circuit Malfunction (High Input)
P1700 Throttle Position Sensor Circuit Malfunction
P1700 Throttle Position Sensor Circuit Malfunction for AT
P1701 Cruise Control Set Signal Circuit Malfunction for AT
P1703 AT Low Clutch Timing Solenoid Valve Circuit Malfunction
P1706 AT Vehicle Speed Sensor Circuit Malfunction (rear wheel)
P1707 AT AWD Solenoid Valve Circuit Malfunction
P1708 Throttle Position Sensor Circuit Low Input
P1709 Throttle Position Sensor Circuit High Input
P1710 Torque Converter Turbine 2 Speed Signal Circuit Malfunction
P1711 Engine Torque Control Signal #1 Circuit Malfunction
P1712 Engine Torque Control Signal #2 Circuit Malfunction
P1714 Throttle Position Sensor Power Supply Circuit
P1716 ATF Temperature Sensor 2 Circuit Low
P1717 ATF Temperature Sensor 2 Circuit High
P1718 AT CAN Communication Circuit
P1719 ECU Communication Circuit
P1760 Lateral Acceleration Sensor Performance Problem
P1761 Lateral Acceleration Sensor Circuit Low
P1762 Lateral Acceleration Sensor Circuit High
P1798 Gear 1 Engine Breaks
P1799 Interlock
P1817 Sports Mode Switch Circuit (Manual Switch)
P1840 Transmission Fluid Pressue Sensor Switch A Circuit
P1841 Transmission Fluid Pressue Sensor Switch B Circuit
P1842 Transmission Fluid Pressue Sensor Switch C Circuit
P1843 Transmission Fluid Pressue Sensor Switch D Circuit
P1844 Transmission Fluid Pressue Sensor Switch E Circuit
P1870 Front Left ABS Sensor Signal
P1871 Front Right ABS Sensor Signal
P1872 Rear Left ABS Sensor Signal
P1873 Rear Right ABS Sensor Signal
P1874 Circuit of R-Diff Oil Temp. Switch
P1875 Circuit of Centre Differential
P1876 Not Suitable Diameter Tyre
P2088 OCV Solenoid Valve Signla A Circuit Open Bank 1
P2089 OCV Solenoid Valve Signal A Circuit Short Bank 1
P2090 OCV Solenoid Valve Signal B Circuit Open Bank 1
P2091 OCV Solenoid Valve Signal B Circuit Short Bank 1
P2092 OCV Solenoid Valve Signal A Circuit Open Bank 2
P2093 OCV Solenoid Valve Signal A Circuit Short Bank 2
P2094 OCV Solenoid Valve Signal B Circuit Open Bank 2
P2095 OCV Solenoid Valve Signal B Circuit Short Bank 2
P2098 Post Catalyst Fuel Trim System Too Lean Bank 2
P2099 Post Catalyst Fuel Trim System Too Rich Bank 2
P2100 Throttle Control Motor Circuit Open
P2101 Throttle Control Motor Circuit Range/Performance
P2102 Throttle Control Motor Circuit Low Input
P2103 Throttle Control Motor Circuit High Input
P2109 Throttle Angle Sensor Closed Position Error
P2111 Throttle Valve Open Stick
P2122 Accelerator Position Sensor D Low Input
P2123 Accelerator Position Sensor D High Input
P2127 Accelerator Position Sensor E Low Input
P2128 Accelerator Position Sensor E High Input
P2135 Throttle Position Sensor Circuit Range/Performance
P2138 Accelerator Position Sensor Circuit Range/Performance
P2707 Shift Solenoid F Malfunction
P2709 Shift Solenoid F Electrical
